I have a B&S 2L surface grinder, same basic grinder as the 2B you are looking at, but with power feeds and power traverse, all mechanical. Made in 1946, got it from HM member Benmychree. It has the plain bearing spindle, not the ball bearing spindle which was the other option. I cannot tell which spindle the one you are looking at has from the photo posted. The plain bearing spindle on mine was apart and needed to be rebuilt. I was able to do that by cobbling together a poor man's "clean room." The spindle was full of grit and other junk, which was causing it to lock up. It is built with a very slight taper which is carefully adjusted for a tiny clearance between the spindle and the bronze bearing blocks. I was able to get the spindle working properly. Everything else on the grinder, including the amazing mechanical clockwork that moves the traverse and table, were all operational. The 2B has simple mechanical controls, which are not complicated at all, but should be checked carefully for wear, as should all used surface grinders. Grit is the silent killer of surface grinders. Take the table off (lifts right off, only held on by gravity) and look for signs of grit, worn ways, and any missing grit shields.
