- Dec 25, 2011
- 10,513
I doubt that it would last more than a few weeks. Plastic isn't strong enough for the set screw, the Woodruff key, or the direct drive pin, spring and set screw. And the index holes would be easily damaged.
That's actually pretty clever. You'll still need a furnace to fire the crucible in and need final finish (like a lot of castings) but overall, I'd say it's a fairly novel approach.
With the right metal powder and a furnace that's hot enough, you'd certainly get your gears out of it.
Sent from my SM-G950U using Tapatalk
Just for reference
Tensile Yield Strength
Zamac 30,200 psi
Aluminum 6061-T6 40000 psi
PLA 9500 psi
ABS 4,300 psi
Nylon 5,800 psi
Polycarbonate 10,000 psi
PVC 6,500 psi
1018 steel 63800 psi
12L14 steel 78300 psi
Have you got shear figures for them all for the same thicknesses rather than tensile strength ?
Cool. I am actually in need for some threading gears. Can you guys make some recommendation on what 3D printer to get? I don't know much about the 3D printer at all.
