- Apr 23, 2018
- 6,557
@silverhawk, a rack and pinion is not going to work. A reloading press has a compound lever that cams out at the top of its stroke. It's the TDC that stops the press, not force on the load.
You want to see an example of a well-built press, check out the Redding Big Boss. Loads up to .50 BMG. Not too expensive in the grand scheme of reloading. That's assuming you're a rifleman. Pistoleros and AR nuts exit immediately right at Dillon.
