- Nov 23, 2014
- 2,610
The drill jig is a plate of steel with your hole pattern. If it's made from hardened steel, the holes will hold up better to running a drill through them.That's a lot to digest but thank you.
It sounds like a fun project down the road but for making only four a month I'm thinking it's way overkill. Maybe the Roper hand punch is the way to go. I don't know what a hardened drill jig is.
For only 4 parts a month I'd use a glue stick and a paper pattern. Carefully center punch your holes right on the paper pattern and go at them with the RW#5.
Bruce
