Has anyone converted a wood cutting bandsaw to cut metal? I have an early 50's era 10 inch Rockwell/Homecraft Banadsaw that I would like to use to cut stainless steel rifle barrels. I know that I have to run the saw much slower on metal than on wood. To that end, I have a 3 phase 1/3 hp motor and a Minarik VFD that I am planning on using. I am open to suggestions as to what speeds and blades to use. Researching bandsaw blades makes my head spin. I also need advise on welding blades. The bandsaw originally used a 71.5 inch blade. I put some new neopreme tires on the wheels that were thinner than the originals resulting in the blade being too long (ran out of adjustment). I suspect that I will need about a 70 inch blade and I don't see that size as being standard. I am open to suggestions and anxious to hear anyone's experiences doing this.
Thanks,
Earl
Thanks,
Earl
