- Feb 8, 2014
- 11,144
Gunrunner you need to order a set of these for the Z axis hand crank. Bill did you just spit coffee on your monitor? :rofl:
I have run manual machines all my life except for at one job. They had a Proto-Trak there that no one used. I took it upon myself to play with it in my spare time, which I had a lot of at that job. It was real easy to learn because it was conversational although there were a few things you had to know that were not always on a blueprint. That's where having cad came in. But as far as other cnc machines I have seen some very costly crashes happen when someone misses something in their program. I could not afford a crash so will stay with manual machines. Unless someone happens to have an old proto trak they are giving away.
There is zero reason to crash a CNC machine due to the program, ever. It happens but its not the fault of the program. A newly written CNC program can have a programming error that will crash a machine yes, that's why new programs are proofed by an experienced operator, at a much reduced speed with the operator reading and understanding the G code the machine is about to execute next to avoid crashing the machine.crash?
