- Apr 30, 2015
- 11,328
Yes you have a bad connection somewhere in there, some of those terminals look positively nasty with corrosion and dirt
You can start by probing the transformer but I suspect the fault is somewhere else
See if you can locate any loose wires or screw terminals first- you may find a wire that pulls right out of it's lug
A voltmeter could be used to go point by point and track down the failure, but I've often located faults like this by just wiggling wires (with an insulated stick, and gloves)
-M
-M
