- Jul 20, 2012
- 1,238
I got one of these and it has been great. A tachometer that can give RPM or SFM (Surface Feet per Minute). Like you said you need speeds for the different diameters. This tachometer tells you exactly what speed you are turning by measuring it from the spindle and you look up the SFM from a chart based on the metal and diameter. With the tachometer going and data from the chart you know for sure you are optimal speed.
I think it would be helpful especially for someone new to machining. With experience people will tell you that you can just know and feel what the speeds should be.
http://www.machtach.com
