Have you ever had a wheel explode? In over 50 years in the trade, I never have, if you don't count accidents running into parts on the surface grinder, there, it was not so much explode as break.
Hello..I wouldn't prefer CBN for HSS at all. Too slow, too hot. Norton 32A (white) for general work and 32AA (purple) for cool, heavy removal. I do use CBN for carbide, though.
i use 120grit CBN to finish my HSS tools to a mirror finish
i rough with AO 32 and 46
View attachment 338416 View attachment 338417
Hello sir...Used belt sanders are not expensive in my area. I paid $40 dollars for my used delta 2x42. I have spend another $20 or so on belts. The work horse is a 36 grit ceramic. Then 80 grit AO, 300 grit AO and I have a leather strop belt for finishing the edge on a knife.
I started grinding HSS freehand with my high speed 4 inch makita grinder. Those bits didn't work too well. Next came a dunlap 6" bench grinder. Big improvement over the makita but still a struggle. Next came the delta. No comparison to the bench grinder. With no practice whatsoever I was able to grind whatever shape or angle I wanted. Having truly sharp tool bits with the correct geometry increased my skill level more than anything else that I have done.
A bench grinder has its place in a shop. But I would get a belt sander before a bench grinder.
I've been using the AO wheels that came on the grinder. They work well, but my plan is to eventually replace them with CBN.
I like the idea of a belt grinder but it seems unless you spend $1000+ that is a project. Either DIY from scratch or modify an existing $300-500 machine to make it suitable. Mikey has an older Craftsman that he likes but that one seems to be a unicorn, and very hard to find in the wild.
