- Jun 12, 2014
- 4,817
Often you can pick up these older disc drives on ePay for next to nothing, if you can find the same exact model in a working drive, you may be able to remove the platter from the broken drive and put it into the other drive. As long as the platter is not damaged/broken and you can get it out, then may be worth a try. Since once open to the air and contamination, it is a toss if/after you get the data off of it.
Information can be written in many different ways in a hard drive, and it is often fragmented in different section across the disc(s), so if any of the heads/dics(s) where damaged the disk would fail. Had this happen to me years ago and also more recently, I always back up everything to a second portable disc and also have dual drives in all my computers. It still sucks when it happens.
