- Nov 25, 2015
- 8,410
You guys; DO NOT, I repeat, DO NOT use EP gear oil with bronze worm gears; it is corrosive to the bronze and when used, it corrodes the bronze, then the worm wears it off, a continuous process leading to early failure.
From http://www.lsc-online.com/industrial-ep-gear-oil/
PRODUCTS & SERVICES- QUALITY
- PACKAGING
- EXPORT & LOGISTICS
- ABOUT US
- MEDIA ROOM
- SDS
- CUSTOMER LOGIN
- INDUSTRIAL OILS
- GEAR LUBRICANTS
- METALWORKING FLUIDS
- SPECIALTY OILS
PREMIUM INDUSTRIAL EP GEAR OIL (NON-LEADED)
Product Description: INDUSTRIAL EP GEAR OIL is formulated from high quality high VI base oils combined with selected additives to provide resistance to foaming, rusting, corrosion and oxidation. A sulfur-phosphorus additive is used to give this oil its extreme pressure characteristics which permit industrial gears to withstand heavy loads and shock loading. Unique additive package employed in industrial EP Gear Oil is non-corrosive to brass, bronze, steel or other alloys.
