- Nov 27, 2012
- 7,866
And for HSS? I will try to find a candidate there.
HSS inserts for indexable tools aren't really common.. The only one I'm aware of that makes them is AR Warner.
I am okay to pass on HSS for now. Many of the descriptions for HSS inserts indicate that they are to be used for cutting aluminum.HSS inserts for indexable tools aren't really common.. The only one I'm aware of that makes them is AR Warner.
I ended up buying these because it will be shipped from the USA:
I'm floating in the same boat, inserts are maddeningly complicated to me. "Just look for this" , then find inserts with more letters, and decimal point numbers than you can shake a stick at. I can find the first 6-8 or so letters/numbers on the charts, but I'm not finding applications, I'm still figuring that out. HSS is easier for application, but geometry is a question mark too, Mikey's HSS thread has a lot of info for that.
