Hi all,
I bought a basket case g4003 variant but it was priced right.
The first issue I’m having is the quick change levers while on the feed rod setting and the same issue but lesser when on the half nuts. The quick change levers are moving up and down while in pin holes, some times one will even eject itself from its position. One of the levers has been repaired seems well done but could be the issue. I’m not against ordering one or two new ones from grizzly they aren’t horribly expensive. I did turn a new shaft that they are on the old one was also diy and too short. The clearance between the shaft and levers is pretty tight but does spin with some resistance, maybe that could be part of the issue but I’m unsure.
The shaft with the gear that runs the feed rod it’s counter part on the apron fell off, it wasn’t clipped or bolted but did have a split roll pin driven in to shaft and gear laterally, which doesn’t seem right. I thought about re drilling where old pin was and replacing with another and maybe tapping the end for a small bolt.
Anyone see an issue with this?
