- Apr 8, 2013
- 1,982
I'm having a little trouble following this thread. You said in one of your posts that you weren't using the tailstock but then you show pics of the part supported in a live center. First you have to turn a piece with the far end unsupported so that you check the alignment of the headstock to the bed. If it's off you can't adjust that with the tailstock. Once you determine the headstock is aligned then you can proceed to check the tailstock. Maybe you did all this already and I missed it.
