Husky A1S - 8x30... Just purchased my first mill.
MikeInOr
Jan 1, 2018
1,200
Hello.... New here. Like many others on here I have wanted a mill for hobby use for the greater portion of my life. After many (20+) years of keeping an eye out the stars finally aligned and I found a mill that will fit in my shop, I believe will be big enough for most of what I want to do, and I had enough money in the bank to cover the price. I just got home from purchasing a Husky A1S 8x30 mill for $1000 and another $200 for a Kurt vise... I am pretty excited. The seller is going to bring it over tomorrow evening and help me unload it. After watching a million youtubes I think it is in good enough shape to suite my purposes. The spindle was quiet on high speed. There were scrape marks on the ways. The table appeared pretty tight. I could not detect any runout on the spindle with my dial indicator. I know the Husky is a generic Taiwanese mill and the big brother to many generic 6x24 mills. I have been close to purchasing mill drills many times... I think this 8x30 will be a bit more capabable for what I want to do. I hope I did ok!
Like everyone else I want to learn about machining (I have had an Atlas 12x36 lathe for 30+ years now that I am somewhat proficient on). Make some odd parts and maybe do a little gunsmithing. I am an old machine junkie but mostly in the wood working world. I have dragged home old machines and restored them just because I have felt sorry for them. I have a bit of a weakness for old radial arm saws and a late 40's Redstar 16" 7.5hp turret arm RAS is the center of my woodworking shop.
I will post pictures when I get it unloaded tomorrow.
Welcome to the Forum!
i can't wait to see your new girlfriend!
congratulations!!! :grin:
Welcome to the forum.
Ras are not my favorite machines, I've owned a few, worked on many. I guess it's because I'm getting older and know just one "senior moment" and you are missing a body part:cool:
Looking forward to seeing the mill though! Congrats!!
Rich
Rich
Heck I've felt that way about RASs since I was in my twenties.
There are though, some magnificent designs in the old ones.
Welcome aboard Mike!
Thank you for the welcomes!
My new mill comes with no tooling. The seller got a great deal on a Bridgeport so he is keeping all his tooling.
My new 8 x 30 has an R8 taper. I "Believe" I need a set of R8 collets. A couple end mills to practice with. Probably a R8 shank to mount a chuck. I have a pretty nice Jacobs chuck for my Atlas lathe. I think it sits on a #2 Morse Taper for my lathe. Should I get a #2 MT to R8 adapter? Or just pick up a R8 shank and a good used Jacobson to dedicate to the mill? Where should I get a set of collets from? I am a fan of Grizzley tools shaper cutters for woodworking... is there mill tooling acceptable? Should I look on ebay? Any other suggestions? Any other tooling I should pickup to start with? A set of parallels?
P.S. I spent a year watching a Walker Turner geared head RAS rotting under someones carport. I finally offered them $40 and it followed me home. Lots of work with a wire wheel and all new bearing... she turned out beautiful! I feel ashamed about running an abrasive blade on it to cut metal... but I already have 2 nice RAS's for wood. The WT has the nice cast iron base on it.
Hi MikeInOr,
Yes a set of R8 collets is a good idea
Some r8 Weldon Tool Holders are very nice, but not completely necessary at first(unless you have the endmills with a flat machined in the tool)
Parallels is a must too, or at least some very accurately ground material ( HSS tool blanks can be substituted in a pinch)
Grizzly's tooling is import, some is good, others not so good- but they really don't sell junk.
I'd think about using 5/8" or 3/4"shanks on your different tooling, like drill chucks and fly cutters and use a collet in the spindle for quick change outs
you can buy quality used collets on Ebay
or
new sets are inexpensive from Shars (http://www.shars.com/products/toolh...?collet_category=Collet+Sets&collet_series=R8), or All Industrial Supply(http://allindustrial.com/all-indust...1-for-bridgeport-with-r8-collet-rack-12-slot/) or JTS Machinery (https://jtsmach.com/jtswebshop/Workholding/CH044.asp)
i hope the info is helpful
PS, i always wanted a WT drill press :grin:
Ulma, thank you. Very helpful! I was just looking at a set of the Shars collets on ebay last night and realized I had no idea what to look for as far as quality tooling that I would not regret purchasing later. The recommendations are very helpful! Thanks for the tip on using a collet to hold a drill chuck for quick tool changing... something I hadn't thought of but it makes a lot of sense.
A couple pics from the CL add.
What do you guys think of this chuck? $96 on ebay... $200+ new w/o arbor. The arbor on this chuck is 3/4". To me it looks dirty but in good shape... it looks like it hasn't had much use to my eyes.
Ball Bearing - Taper Mount
■ Ball Bearing Construction Maximizes Gripping Force and Drilling Accuracy
■ Jaws Center-Ground for Straightness and Alignment
■ One-Piece Sleeve Eliminates Crack Between Driving Teeth Often Found in Other Designs
■ Through-Hardened Sleeve Teeth Plus Hardened Nose and Keyholes Provide Outstanding Wear Resistance
■ Fluted Sleeve Standard
■ Each Chuck 100% Inspected for Performance and Precision
■ T.I.R. 0.003"
Model: 14N
Min Capacity: 0.040 in
Max Capacity: 0.500 in
Closed Length: 3.88 in
Open Length: 2.97 in
Sleeve dia: 2.97 in
Weight: 2.44 lb
That looks very similar to my Grizzly G1008 mill which also has 8x30 table. I purchased this second hand end of Jan 2017 so almost 1 year ago. The seller purchased this new in 2000.
Mine came with a set of R8 collets. I purchased a Jacobs chuck with R8 mount. I have purchased a number of items from Shars in the past year.
My Grizzly does not have a quill lock, so I need to hold the quill pulley to tighten or loosen the collet. Not a problem.
You will need a mill clamping kit. Available from many places, even Harbor Freight. Just measure your slots so you get a set with correct T nuts.
Yes Dave, very similar mills. I couldn't find much info on Husky mills so I ended up doing a fair bit of reading on your Grizzly before making my decision. Most owners had pretty positive reviews on the Grizzly 8 x 30 mills. Are you pleased with yours? Did your mill come with the DRO and power feed? Both options I would like to add eventually. The one feature my mill doesn't have that really bothered me is the one shot lube. It seems like a mill would have probably received better lube over its life if it had a one shot lube.
Do most people prefer the Keyless chucks over keyed chucks? I see a lot of pictures of mills with keyless chucks. All my drill presses have always had keyed chucks.
