- Apr 20, 2015
- 50
So, My recent haul of used machine tools and bits has given me lots more to learn with.
While working yesterday on making some t-slot nuts, I was switching through different end mills trying to find what worked best for the particular job.
Essentially, one issue I noted was that the HSS end mills (new) I used really had some bad chatter taking 0.020 depth of cut, 1/3 the cutter doing the work (1/2" 4 flute end mill) in some off the shelf cold rolled square bar.
--> Using cheap "cutting oil" from Princess auto.
I noticed that it seemed to be re-cutting chips pretty badly, which I assume was the issue.
It seemed to me that the cutting oil was not allowing the chips to leave the cutter, and thus re-cutting the chips, causing the whole process to go slow, sound and feel bad, and in general not be pleasant.
Note: By the end of the cut, the part was still cool to the touch, and I could see the cutting oil was muddy with micro-chips.
This bring me to the first set of questions:
No matter the bit material or cutting fluid, I should expect the chips to "eject" from the work area, correct?
--> I was getting a shoddy muck of cutting fluid, micro chips, and some small chips, but all in the work area.
What viscosity should cutting oil be for this application? (I think the cheap **** I have may be intended for another purpose, it's pretty viscous.) 10w30 thick, but appears to be dedicated cutting oil.
Should cutting fluid be constantly applied, or should I just put a light coat on the work piece before I begin?
--> Seems like my brush may have been helping to keep the chips on the cutter?
Can you mill with HSS bits without cutting oil? Or will I quickly destroy the bit?
I'm still learning the whole speeds and feeds thing, but what are the signs that I am working at too high an RPM?
--> I am unsure if the noises my mini mill are normal, or alarming, so I fear I am either over working, or under working the machine's capabilities. I suspect under working the machine, due to the lack of chip ejection, but on that same note, the machine is making some noises I am not yet comfortable with.
Carbide end mill was used as well. Same process as above, but without cutting fluid.
Chips were flying, turning light brown, all was good. Cut twice as much material at three times the rate.
Obviously, am much happier with the carbide end mill and would love this capability from all of my HSS tools too.
So what were the differences between the carbide, and HSS tests:
Both 1/2" end mills
Both 4 flutes
(Same or better depth of cut)
Carbide vs HSS
No cutting fluid
I have so many HSS tools, I need to figure this out, but I am tempted to just switch to using carbide all the time based on yesterday's results. Need to learn! Help!
Both 1/2" end mills
Both 4 flutes
Carbide vs HSS
No cutting fluid
