[How-To] How would you?
And I would cut the bore at just under the 2.375 and offset each side for minimal blend and less chatter. Use the knee to feed up instead of the quill.
And by up, I mean to advance the boring head down into the work. Feeding with a clamped quill and using the knee is more rigid.
Three holes.. Center, Upper, then Lower. at least, that was what I was taught.....
AS promised, film at eleven....or thereabouts!!
slow process, gotta be a better way
I have a regular hole saw set up to 2.5" by 1/4" increments, I may try that on the next one.
I have 4 of them to do.
So what if its 1/8" oversize!
Little Hydros ? I started out with a 8 HP red 283 . :grin:
Nah, these are the model 383 Cat 0 for supers.
