How would you set up and clamp this part on your mill?
I have a 12x14" 1/4" thick steel plate. I need to make three 7/8" diameter holes in it with the centers of the holes representing the three points of an equilateral triangle with each leg equal to 11.5 inches. The altitude of the triangle is 10 inches.
How would you support the piece off of the table so the drill bit/boring bar does not contact your table? Or do you try to align the intended hole locations with the T-slots in your table? I don't think they're 7/8" wide, but if the holes were smaller, would you entertain that as an option?
Do you set it on parallels laid flat on the table?
The workpiece is too big to be held by the vise.
