- Feb 1, 2015
- 9,621
The rack and pinon on a 618 is hardly precision gearing. I wouldn't worry about bending. I popped mine off in less than a minute using gentle force. The teeth on the rack do not extend to the far side of the rack, leaving a gap that can be used with a pry bar to pull the pins. I used an offset screwdriver as a pry bar. A church key would also serve as a miniature pry bar. The pins are pressed into the rack and a tight slip/loose press fit in the lathe bed.
