- Dec 27, 2014
- 4,056
If you compare the area of surface between inside and out you will find the inside to be much smaller, less friction. That's why bushings are stationary relative to the shafts inside them.
Rob, Do you ream the new bushing by hand? Or do you fixture the part and ream it on a machine?
Cor that stirred the old grey matter in the bone dome..After considering this more and some Google research, I remember that the calculation for friction force is only affected by normal force and coefficient of, not area. So I believe my question is still unanswered.
Steve Shannon
What about a steel sleeve, pressed onto the steel shaft, which would run inside the cast iron piece? The actual application is the shaft within a backgear for a lathe. The replacement backgear has a bore that is 50 thousandths of an inch larger than the existing eccentric shaft.In the likely event of a lubricant film failure, the probability of survival is much greater using a steel shaft in a fixed bushing vs a bronze shaft (essentially) running in a cast iron piece.
