- Nov 8, 2020
- 44
On my Deckel FP1 the gearbox for the X and Z feeds has a little problem that I wanted to address. Everything is pulled apart and the problem is already spotted, a worn thrust washer causes misalignment of the drive dogs for the Z-axis feed and so when the Z-feed is not turned on the feed is still engaged, wanting to move the table in Z.
Things could be so easy... I have looked it up in the manual and there are only two tapered pins holding the whole feed shaft in place. Remove those pins, pull the axis apart, machine a new washer and put everything back in place.
But like seemingly everything else the previous owner pulled some super shady things on this one...
One of the tapered pins was spot welded in place, so something must have caused problems before or this was just his solution to the above mentioned problem. I tried to grind the spot weld away with a dremel but I had no luck so far. In the second picture is the thicker side of the tapered pin and you can already tell there is something going on with the tapered hole... as if it had been redrilled multiple times? What is also odd is that the pin is crooked inside the bore, see picture three. I can't imagine it was bent by hammering on top of it, it looks like the whole pin and bore is crooked? I have no idea what is going on here...
Here is the thinner side of the pin. I tried to grind away the spot weld with a dremel, but I still can't get it out...
I guess the only thing left is to drill the pin out? It it s a 4mm pin and I would punch mark the thicker side and drill with 3mm, and 4mm if needed? If have never done this before and I am still hesitant to do this. There are no more spare parts for this mill and if I mess something up I am in even bigger trouble.
So what do I do, besides approaching the previous owner and punching him in the face?
