- Apr 23, 2018
- 6,617
The most important thing to consider when setting up a rotary table is preserving center. Most rotary tables have holes in them, and, at least found on decent tables, that hole will have a precision taper. My funky-cool Kamakura RT has a weird/proprietary metric taper center , but who cares about proprietary, I own a lathe. I turned a few center taper "blanks" out of aluminum bar. When I need a threaded hold-down on center, I just whip one up a taper plug with the thread I need on center. When I need to mount a threaded chuck, I'll grab a blank and thread it, then plunk the chuck on top of the table, centered on the taper- piece of cake. I have a library of RT centers forming now, so some setups are off-the-shelf, literally. Every rotary table setup needs at minimum a hole or a dimple at center, but the humble taper is the most versatile. You can ream your own Morse taper and use morse tool/work holders, including an ER collet holder, which is a very nice thing to have on a rotary table! With a taper interface, you don't need to re-center the chuck or setup like you do with t-slot bolts every time you swap fixtures. The taper is always centered, wasting no time. You change tools in your tailstock without blinking about alignment routinely, so outfitting your RT to work the same way just makes sense.
