How do you mill long 1m sections like 10mmx10mm (thats 3ft of 3/8 x 3/8)
First problem is the stock I get is bent, sometimes badly.
Second problem is - you can't take anything but a very small cut - the stock flexes.
Third problem is - if it is slightly bent clamping it straightens it - so how do you machine it true.
Fourth problem is - you can only machine a small section - it flexes.
How do others tackle it?
