How to measure and lay out plans on a beginer/hobby level
mac1911
Sep 29, 2022
743
Im trying to make a simple part. Im just not sure how to lay out the off set shafts.
Plan is to machine the “flat” part and the longer shaft out of a a piece of stock and then drill a press fit for the shorter stub.
Im just not seeing clearly how to lay it out and measure it.
Yes I'm not quite sure what you are asking. More information, please, a rough sketch, photos of existing or similar parts, etc. Anything, could be very helpful for us to understand what you want.
I am not even sure how to ask the questions…..
I need to make this part.
How do I accurately measure the offset of the two “shafts”
Here this may help:
One method of measuring the shafts:
First measure the diameters of both shafts.
Set the larger shaft in a V-block, laying horizontally, on a surface plate with the lobe and small shaft hanging off the end.
Measure to the top diameter of the large shaft with a height gauge or dial indicator on a base.
By rotating the part in the V-block, Measure the height of the small shaft when it is at its lowest point to the plate.
Subtract half the diameter of the large shaft and add half the diameter of the small shaft to the difference between the two.
That will give you the center to center.
You have a worn part, so you will have to extrapolate where and how the wear affects any measurements. I can't see the part to offer much help with that. Maybe there's an unworn or less worn area of it?
I'm also going to assume that you don't have a way to measure the dead nutz centerline of a tool bit on your lathe, for a single point touch off to be absolutely positively on center. That would work too, but the workaround is pretty simple....
Take the main, larger, longer shaft end, and stick it in your lathe chuck. Make that run as true as you need it to.
Take your tool post, a holder, or anything with a flat vertical surface, that you can get near to the offset, shorter part.
Manually rotate the chuck/part until the offset is directly towards you. the tool post, and the flat surface you've arranged.
Move the carriage towards the part, moving the part back and forth so the offset moves JUST above and below center.
Find the point where the part JUST touches the flat surface you've arranged at some point in that movement..
Zero your dial, DRO, or whatever. Your zero that you've just made will be one radius of the small shaft away from the centerline.
Rotate the chuck/part 180 degrees, so the offset is away from you, away from the tool post.
Move the carriage to the new offset shaft position, and find that carefuly the same way. This time it will hit the flat spot when it's off center, and on center will be loose. Gently, carefully, run right up to the point where it's touched at it's furthest extreme.
Read your dial/DRO or whatever. This reading is one shaft radius away from the centerline.
The extra radii in your measurements are both offset in the same direction, and will cancel out in the math, leaving and leave you with the exact travel reading on your dial/DRO or whatever will be the total diameter, or "swing" of the offset piece. A diameter.
Because you're looking for an offset, a radius of the "swing", dividing that number by two will give you the offset you're looking for.
Thanks all, Im just having a hard to visualizing all this. I have zero “training” in machine work. I generally find ways to get where I need to be. Im just tired of the long way I generally take.
One of those things science folks say is that men are better at spatial reasoning. I’m not.
But I just wanted to thank you for asking your question. These sort of “how to figure it out” questions are valuable for everyone.
Hey there! Making a simple part can be tricky. First, sketch it out on paper to visualize it. Then measure and mark your stock accurately. Use calipers for precision. Good luck!
Yup , I hate when I look st something and think , oh thats easy.
But trying to find the center of a worn out shaft on a part that is also worn and or not “square” . I will get it at some point.
Walker wanted $160 for the crank shaft…..thats not happening. I have more time at home than money.
