How To Make A Wire Clamp Tool.
Digitallad
Active Member
Active Member
Jul 16, 2013
43
Likes
86
#1
I saw a wire clamp tool made by clamptool.com the other day and thought it should be easy enough to make for home use.
The pictures should be self explanatory so here goes ..
I like to use some paper tightly wrapped around the finished bit to protect against the jaws and it works quite well for me. I parted and then cut the taper
The rear parting tool still works like a charm
The finished taper
Lined it up in the mill to cut the slots
Slot almost done
I used some brass to make the turn handle.
Milled a flat on the one side to thread
Drilled and tapped the handle
There after I case hardened the tip and drilled a 4.5mm hole in the threaded rod and installed a roll pin then assemble
Some notes: I opted not to install the front pin as per the original and I can say that it makes a difference after testing it. I made the tip to wide and will make a thinner tip for smaller/thinner wire clams.
All and all a fun and useful project to do.
Regards
Paul
Ed ke6bnl
Active Member
Active Member
Nov 20, 2014
415
Likes
143
#2
On my first lathe a 9" southbend that was one of my first project never used a lathe before. We started with turning pvc then went on to this project. Yours is far nicer then mine which was more basic. I finally changed the front pin to a rolled hardened pin. Making a new better one is in the plans. but the old one is working fine. I do not see the little notch in the point, just not showing in the pictures.
Bob Korves
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Jul 2, 2014
4,023
Likes
4,171
#3
Er, pardon my ignorance, but what does it do and how does it work? Nice machining job...
dlane
Sep 27, 2014
2,206
Likes
877
#4
Nice looking tool , and thanks for full size pics .
Not real sure what a wire clamp tool is for (yea clamping wire) but the application?.
Thanks for posting , guess I'll research it.
shoot summ
Iron
Registered Member
Feb 1, 2016
9
Likes
4
#7
My Brother is actually the guy that sells that tool on Clamptool.com, he can do some crazy wire clamps with it.
oldboy1950
Active Member
Active Member
Dec 17, 2014
104
Likes
74
#8
i looked at this post earlier this morning and thought what a neat tool and nice machining but had no idea what it was for...now i know !
thank you, now i just may make one for myself.
Dan
Digitallad
Active Member
Active Member
Jul 16, 2013
43
Likes
86
#9
Not a grate pic but yes the "cotch" is there.
f350ca
Active Member
Jul 11, 2013
1,178
Likes
1,831
#10
Great job, I have a small one I bought, have been wanting to build a bigger one, maybe this will inspire me
Greg
ch2co
Grumpy Old Man
Jan 9, 2013
752
Likes
461
#11
Pretty cool tool! Never saw one before, but I have seen wire clamps on a lot of equipment. When not using a screw thread hose clamp, I've always used Band-it tools and straps for the higher end terminations. High quality but rather expensive. This on the other hand needs to be incorporated in a Leatherman multitool. Thanks.\
CHuck the grumpy one
ARKnack
Active Member
Active Member
Dec 19, 2014
161
Likes
85
#12
Interesting. What kind of wire do you use. It looks like it needs to but soft enough to bend but strong enough not to stretch or brake. A side view picture would be nice also.
terrywerm
HM Shop Foreman
Staff member
Oct 21, 2012
3,526
Likes
881
#14
I made a similar tool a couple of years ago, and it has come in quite handy. You did a nice job on yours, much fancier than I made mine. I made the main body and used a piece of 3/8" threaded rod with a wing nut on it. Works just fine!
atlas ten
Active Member
Active Member
Nov 17, 2014
173
Likes
58
#15
I'm sure going to find one these handy after I make one. Now to find some scraps. I'm thinking mechanics wire will work.
Jack
Sent from my SGH-I337M using Tapatalk
FOMOGO
Sep 2, 2013
1,451
Likes
1,174
#17
That's pretty cool. Have never run across one before, but sure looks like it would be very useful on a lot of applications and would save quite a bit on hose clamps, which are getting hard to find in any kind of quality material. I would think a stainless wire in several diameters would be the way to go for most things. Mike
terrywerm
HM Shop Foreman
Staff member
Oct 21, 2012
3,526
Likes
881
#18
I have used wires of different sizes and materials. They all work quite well.
Sent from my SM-G360T using Tapatalk
Digitallad
Active Member
Active Member
Jul 16, 2013
43
Likes
86
#20
I have found that almost any wire will do depending on what you want to clamp. I have a tool that I bought few years back that can handle up to 4mm wire and you can just about cut a pipe with it but it is a bulky tool for smaller jobs.
David I like your's better mine is still a bit bulky ,,, back to the shop again.
benmychree
John York
Jun 7, 2013
993
Likes
553
#21
I have one of these tools that is of the original generation; the preferred wire for the clamps is good "ole Oklahoma Silk" or plain old baling wire.
JD8020
Swarf
Registered Member
Feb 7, 2016
2
Likes
0
#22
Almost 50 years ago a friend of mine showed me a tool like this. I made one shortly there after, before I had a lathe or mill. Very crude, but still works. Now I have the tools I need to make a refined version of it. Roger
benmychree
John York
Jun 7, 2013
993
Likes
553
#23
Another observation is that the one that I have, mentioned above does not and never did have the forward pin shown in the pictures at the start of this thread, and it seems to work fine in spite of it. I also use Punch Lock clamps, but they do not seem to draw down and seal as well as the wire clamps, especially for small hose.
coherent
Active Member
Active Member
Aug 6, 2013
106
Likes
55
#24
I've made wire clamps using a cheap pop rivet gun (pliers). Just twist the wire and leave a loop on the very end. Loop around your hose and thru the loop. Then feed the end of the twisted wire through the gun tip and pull it tight with the rivet gun handle... bend it back and clip. Should be easy to visualize. No where near as fancy and nice as this tool though, but if you already have a rivet gun handy, it works very well!
Ed ke6bnl
Active Member
Active Member
Nov 20, 2014
415
Likes
143
#25
I like to see more on this one pop rivet gun, I have made 3 other version that work fine but not the pop rivet gun. many of my air hoses have been switched over to the wire clamp method as well as water hoses that neec to be clamped,. I carry one version in my offroad buggy.
coherent
Active Member
Active Member
Aug 6, 2013
106
Likes
55
#26
Not my original post, but I did a quick search and found these photos (post #68 on linked thread) on another forum. Hopefully it's ok to post the link here. I've also seen some really simple and effective one made by using plain metal tent stakes (metal rod is the same) with just a little bending and a couple holes. Very simple to make and work well also.
http://www.tractorbynet.com/forums/build-yourself/273086-show-what-tool-you-made-7.html#post3251479
Container Above bottom breadcrumb
