[How-To] How to learn machining via YouTube
Playlist: Essentials For New Users
YouTube channel: Autodesk Fusion
Channel type: product education, tips, how-to's, examples, projects
List type: playlist all videos, uncurated
# of videos: 23
YouTube:
001-Designing a 3D Printed Enclosure for Arduino Uno
002-Fusion 360 Design a 3D Printed Lampshade
003-Fusion 360 Sketch Constraints
004-Fusion 360 For Beginners - Recorded Webinar
005-Surface Modeling with Fusion 360
006-Designing a Lasercut Laptop Stand with Fusion 360
007-How to Sculpt the New Fusion 360 Logo
008-Boost Design Efficiency with the S-Key in Fusion 360
009-Fusion 360 Patterns & User Parameters
010-Smart strategies to fix model errors & warnings in your Design! Autodesk Fusion 360
011-Autodesk Fusion 360 Quick Tip Using the Ctrl Key or Command Key Shortcuts
012-Autodesk Fusion 360 Quick Tip How to Sketch Tangent Dimensions
013-Autodesk Fusion 360 Quick Tip Body vs. Component
014-Webinar - Fusion 360 - ISO 9001 Quality Management System
015-What's New In Fusion 360 Design & Engineering - October 2020
016-Quick Tip Using Shortcuts to Change between Modeling and Sketch Environments Autodesk Fusion 360
017-Top 5 Reasons to Switch to Autodesk Fusion 360
018-Transform Your Designs How to Create Realistic Threads in Fusion
019-Master Autodesk Fusion Understanding Bodies vs Components [UPDATED!!]
020-Learn How to Show Sketch Dimensions in Autodesk Fusion FAST!
021-From Beginner to Pro Conquer STL Files in Autodesk Fusion [UPDATED!]
022-Create Your First Hard Surface Model in FIVE MINUTES with Fusion
023-Navigate the Autodesk Fusion Interface Like a Pro! [UPDATED!!]
Playlist: Get Started with CAD/CAM in Fusion 360
# of videos: 4
YouTube:
001-Get Started with CAD CAM Tutorial Unlock the Power of CAD CAM in Fusion 360 Autodesk Fusion 360
002-Get Started with CAD CAM Tutorial Your First Model and Drawing Autodesk Fusion 360
003-Get Started with CAD CAM Tutorial Making Your First CAM Document Autodesk Fusion 360
004-Get Started with CAD CAM Tutorial Learning Positional 5-Axis Autodesk Fusion 360
Playlist: Introduction to CAM using Fusion 360
# of videos: 4
YouTube:
001-TUTORIAL Separation of Design and Manufacturing Documents
002-TUTORIAL Understanding Intent in Fusion 360
003-TUTORIAL Fusion 360 for Manufacturing - A first look at Modeling
004-TUTORIAL Intro to CAD CAM using Fusion 360
Playlist: Design to Make Series
# of videos: 7
YouTube:
001-360 LIVE Design to Manufacturing, Part 1 of 4
002-360 LIVE Programming Tool Paths for Spark Plug Bottle Opener, Part 2 of 4
003-360 LIVE Collaboration in Fusion 360, Part 3 of 4
004-360 LIVE Manufacturing Spark Plug Opener, Part 4 of 4
005-360 LIVE Creating the SparkPlug Drawing
006-Webinar - Fusion 360 - ISO 9001 Quality Management System
007-Fusion 360 and the zen of machining
Playlist: Pencil Sharpener Project
# of videos: 10
YouTube:
001-Pencil Sharpener Project - Part 1
002-Pencil Sharpener Project - Part 2
003-Pencil Sharpener Project - Part 3
004-Pencil Sharpener Project - Part 4
005-Pencil Sharpener Project - Part 5
006-Pencil Sharpener Project - Part 6
007-Pencil Sharpener Project - Part 7
008-Pencil Sharpener Project - Part 8
009-Pencil Sharpener Project - Part 9
010-Pencil Sharpener Project - Part 10
Playlist: Brad Tallis for Autodesk Fusion 360
# of videos: 54
YouTube:
001-Tutorial Creating Realistic Renderings in Fusion 360 Autodesk Fusion 360
002-Quick Tip Selection Methods in Fusion 360 Autodesk Fusion 360
003-Quick Tip How to Set Units in Fusion 360 Autodesk Fusion 360
004-360 LIVE Part 2 of the Patio Light
005-360 LIVE Shining Light on the Pipe Command
006-360 LIVE BattleBots & Twisted Parts
007-360 LIVE Drawing Tips & Tricks
008-360 LIVE Derive-ing Lessons
009-360 LIVE Fusion 360 Hangout
010-360 LIVE Laser Projector Build - Part 6 Assembling It All Together
011-360 LIVE Laser Projector Build - Part 5 Heatsink & Gears
012-360 LIVE - Laser Projector Build Part 4 - Crafting the Front Mount
013-360 LIVE Laser Projector Build - Part 3 The Center Housing
014-360 LIVE Laser Projector Build - Part 2
015-360 LIVE Laser Projector Build - Part 1
016-360 LIVE 3D Printing from Fusion 360 to swim with the manatees
017-360 LIVE Manufacturing a Generative Designed Part with Brad Tallis
018-360 LIVE Creating HVAC parts in Fusion 360 Sheet Metal
019-QUICK TIP Right Click is Your Friend
020-Creating a Control Arm for Manufacturing
021-QUICK TIP Add 100's of Fillets FAST!
022-Using 2D DWG DXF to create 3D Model
023-QUICK TIP Formulas in Dimensions
024-QUICK TIP Aligned, Vertical, or Horizontal Dimension
025-QUICK TIP Repeat Command
026-QUICK TIP Dimension Reference Shortcut
027-QUICK TIP Show Dimensions
028-QUICK TIP Sketch Constraints Filter
029-360 LIVE New Features in Action!
030-QUICK TIP Shell To Save Time
031-360 LIVE Fusion 360 Tips & Tricks
032-360 LIVE Creating In-Context Designs (part 3 of 3)
033-360 LIVE Creating In-Context Designs (part 2 of 3)
034-360 LIVE Creating In-Context Designs (multi-part series)
035-360 LIVE Creating Animations & Exploded Views
036-360 LIVE 3D Creating a cardboard box using Fusion 360's Sheet Metal
037-QUICK TIP Auxiliary Views in 2D Drawings
038-360 LIVE Creating the SparkPlug Drawing
039-360 LIVE Manufacturing Spark Plug Opener, Part 4 of 4
040-360 LIVE Collaboration in Fusion 360, Part 3 of 4
041-360 LIVE Design to Manufacturing, Part 1 of 4
042-360 LIVE 3D Printed Threads
043-360 LIVE Old vs. New UI
044-360 LIVE Mastering Assemblies with McMaster-Carr
045-360 LIVE Creating a parameter-driven Sheet Metal part
046-360 LIVE Bringing SVG files into Fusion 360
047-360 LIVE What we've learned from YOU!
048-360 LIVE Design a 3d Printed Flag Pole Mount
049-360 LIVE Photogrammetry with Fusion 360
050-360 LIVE From Concept to Manufacture
051-360 LIVE Lofting to new heights
052-360 LIVE 3D Printing Tips with Fusion 360
053-360 LIVE Electrical Wire Routes
054-Making Changes to History-Free Models using Direct Editing
YouTube channel: Adam the Machinist
Channel type: unstructured, general machining, tips, how-to's, features grinding
List type: channel all videos, additional sources content, curated
# of videos: 29
# of podcasts: 2
**** Note: curated lists may be grouped by topic or project ****
**** curated list order will not reflect the YouTube video order ****
YouTube:
001-additional source: Podcast - Within Tolerance - Within Tolerance Episode 12 - Adam Demuth - source: https://podcasters.spotify.com/pod/...hin-Tolerance-Episode-12---Adam-Demuth-e5f2cc
002-additional source: NYCCNC-CNC Shop Tour - Adam Started His Own CNC Machining Business! - source:
003-additional source: NYCCNC-HOME MACHINE SHOP TOUR! Demuth Tool & Design First Year as Self-Employed! - source:
004-additional source: Podcast - Within Tolerance - Within Tolerance Episode 122 - Adam Demuth - https://podcasters.spotify.com/pod/...n-Tolerance-Episode-122---Adam-Demuth-e1bgue6
005-Concentricity Gage made with 3D printing
006-Magnetic workholding with Nails
007-High resolution machinists jacks
008-Differential gear tooth indexing
009-Hard Milling a V Block
010-Compound Chamfer-The Most Expensive Chamfer
011-Toolmakers boring head trick
012-Milling Carbide with diamonds
013-Shop Math and Grinder Ergonomics
014-Improve your polishing with 3D printing
015-Machining and printing shallow diameter gages
016-Peel Grinding technique for the Surface Grinder
017-Machining a Flexure Nutcracker
018-My very unusual sine bar
019-Grinding small parts perpendicular
020-Chamfering time #instamachinist #machinist #toolmaker
021-Secret Digital Caliper Functions
022-Faster than jig grinding #machinist #toolmaker #engineering #precision
023-Dovetail workholding and copper machining
024-My favorite Machinist trick
025-Shaper Micro Machining
026-Remarkably small hydraulic tool holder
027-Thread-milling without a hole
028-additional source: Patreon-Machining a 1911 source: https://www.patreon.com/posts/machining-1911-96122919
029-Dicing Zirconia
030-The 180 Method For grinding perfectly centered features
031-Removing the mill tool marks on the 1911 - January 23, 2024
YouTube channel: Let's Machine
Channel type: unstructured, general machining, projects, how-to's
List type: channel all videos, uncurated
# of videos: 59
YouTube:
001-BEGINNER CNC HOW TO SET TOOL HEIGHTS IN A VERTICAL MILL
002-LET'S MACHINE STAINLESS SIGNET RINGS
003-LET'S MACHINE HAMMER POMMELS (CNC KNIFEMAKING)
004-LET'S MACHINE CNC BRONZE CHALLENGE COINS
005-LET'S MACHINE 4TH AXIS CNC BASICS
006-LET'S MACHINE CNC SURFACED SKULLS
007-LET'S MACHINE ENGRAVING AN IPHONE 6 BACK & SCREEN
008-LET'S MACHINE CNC MACHINED BRAND (& MASTERCAM X9 DYNAMIC MILLING)
009-BEGINNER CNC HOW TO DRIP FEED A HAAS MILL WITH RS232
010-BEGINNER CNC ENGRAVING TOOLPATHS IN MASTERCAM X9
011-CNC TOOL REVIEW CARMEX THREAD MILL
012-SHOP TALK - When Should I Buy New Tech
013-BEGINNER CNC WHAT TOOLHOLDER SHOULD I USE
014-SHOP TALK - Why You Must Own Your Workspace
015-BEGINNER CNC HOW TO INDICATE A VISE STRAIGHT
016-SHOP TALK The 80 20 Rule & Is There Such Thing as a Bad Customer
017-BEGINNER CNC USING AN EDGE FINDER TO SET ZEROS
018-SHOP TALK Why the Race to the Bottom Hurts Everyone
019-MACHINING VLOG Engraving Rings with Mastercam & Haas VF5
020-SHOP TALK Why After Action Reports Are Absolutely Critical
021-CNC TOOL REVIEW MASTERCUT 90 DEGREE DRILL MILL (CHAMFER MILL)
022-NEW VISE DAY! KURT DX6 CROSSOVER UNBOXING
023-SHOP TALK Why Keeping Your Shop Clean Isn't Optional
024-LET'S MACHINE HIGH-SPEED SCALLOP TOOLPATH TEXTURING W MASTERCAM!
025-SHOP TALK - When Not to Cheap Out on Tools
026-LET'S MACHINE EDM WIRECUT BRONZE STITCHES
027-LET'S MACHINE HIGH SPEED WATERLINE TOOLPATHS
028-SHOP TALK - What Are You Supporting With Your Dollar
029-LET'S MACHINE - MACHINING A TRI-HANDLE FOR THE GYM
030-Take a Tour of My Shop!
031-BEGINNER CNC INTRO TO WORKHOLDING OPTIONS
032-SHOP TALK How to Find Work
033-LET'S MACHINE LONG BRASS PROFILES!
034-SHOP TALK Why You Must Keep Spindles Turning
035-TAKING A PROTOTYPE INTO CNC PRODUCTION
036-SHOP TALK Don't Believe Everything You Read
037-MASTERCAM 2018 WIRE EDM BASICS
038-SHOP TALK Beware Energy Sinks!
039-[TT] BEGINNER CNC STAGING TOOLS TO SAVE TIME
040-SHOP TALK Tooling Reps!
041-MACHINING VLOG SPINDLE CLAMP
042-SHOP TALK WHY EGO IS THE ENEMY
043-MACHINING VLOG WIRECUTTING ALUMINUM PROTOTYPES
044-Shop Talk - Don't Wait for Inspiration
045-[TT] BEGINNER CNC RUNNING TWO PARTS AT A TIME
046-TOOL REVIEW - $40 HAAS LED LIGHTS!
047-SHOP TALK The 3 Rules for Choosing a Vendor
048-LETS MACHINE DOT PEENING
049-Shop Talk Staff Morale
050-BEGINNER CNC - MATERIAL PRE-REMOVAL
051-LET'S MACHINE - ENGRAVING WITH A CHAMFER MILL
052-SHOP (BREW) TALK AUTOMATION TAX!
053-[TT] Fixturing for CNC Machining Thin Aluminum Profiles
054-MASTERCAM WIRE EDM TUTORIAL 1
055-SHOP TALK How to Protect Your Job Security With The Rise of Automation
056-SHOP TALK - Why Less Staff Is Better Than Bad Staff
057-SHOP TALK SALES IS A NUMBERS GAMES (HOW TO FIND WORK PT. 2)
058-A BASIC WIRE EDM JOB
059-SHOP TALK Why You Must Be Protective Of Your Time
Name: Kevin Ellingson
YouTube channel: Mechanical Advantage
Channel type: unstructured, Autodesk Fusion, projects, how-to's
# of videos: 127
YouTube:
001-NYC CNC Part 2
002-NYC CNC Part 3
003-Fusion 360 NYC CNC Sketching Tips
004-Fusion 360 Embossed Text
005-Feature Focus - Inventor marking menu
006-Replacing Splines with Arcs in AutoCAD - Part 1
007-Replacing Splines with Arcs in AutoCAD - Part 2
008-Autodesk Inventor Place Hole On Cylindrical Face
009-Fusion 360 Hole on Cylindrial Face
010-Fusion 360 Hole Command
011-Fusion 360 Hole Location on Cylinder
012-Fusion 360 Offset Hole on Cylinder Face
013-Locating the WCS using Fusion 360
014-Fusion 360 WCS Orientation - Organic Shapes
015-Creating a Fusion 360 CAM Work Coordinate System WCS
016-Fusion 360 - Changing Workspace View Orientations
017-Fusion 360 Stock From Solid
018-Fusion 360 - Relative Size Stock Options
019-Fusion 360 - Fixed Size Stock Options
020-Fusion 360 Flat Pattern Hole On Cylindrical Face
021-Fusion 360 User Interface Customization and Preferences
022-Fusion 360 Navigation - Pan, Zoom, Rotate
023-Fusion 360 - Setting CAM Defaults
024-Fusion 360 CAM - Setting Check Box Defaults
025-Fusion 360 - Secret Hidden UI
026-Fusion 360 - Sheet Metal Normal Cuts
027-Fusion 360 CAM - Selecting Geometry
028-Fusion 360 - CAM Beta Mode
029-Fusion 360 - Autoproject Active Sketch Plane
030-Fusion 360 - Create .stl for 3D printing
031-Fusion 360 - CAM Named Views
032-Fusion 360 - CAM Heights Tab Explained
033-Fusion 360 - Secrets of the line command
034-Fusion 360 - Getting Started with Drawings
035-Fusion 360 - Understanding the Intersect Operation Option
036-Fusion 360 - 3D Surfacing Contact Point Boundary
037-Fusion 360 - Creating Tangent Dimensions
038-Fusion 360 - Create a Feature on a Cylinder Wall
039-Fusion 360 - Getting Started With Parameters
040-Fusion 360 - Facing Toolpath Deep Dive
041-Fusion 360 - Pocket, Open Pocket geometry selection
042-Fusion 360 - Fusion Assemblies
043-Fusion 360 - Patch It Up
044-Fusion 360 - Tube Notching
045-Fusion 360 - Defeature a model
046-Fusion 360 - Project Geometry Options
047-Fusion 360 - CAM Duplication Options
048-Fusion 360 - 3D CAM 1911 Grips
049-Fusion 360 - AnyCad!
050-Fusion 360 - Sheet Metal Rules
051-Fusion 360 - Unfolding Sheet Metal Tubing
052-Fusion 360 - Fundamentals of Sketching and Modeling
053-Fusion 360 UI Preview
054-Fusion 360 - Patch it up part II
055-Fusion 360 CAM WCS Setup Duplication
056-Fusion 360 - What are stock contours
057-Fusion 360 - Simulation Deep Dive
058-Fusion 360 Legacy and Modern UI Comparison
059-Fusion 360 Fundamentals - Modeling a bracket
060-Fusion 360 - Import Mastercam tool libraries
061-Fusion 360 - Copy, Duplicate, and Derive
062-Fusion 360 - Unfolding Sheet Metal Tubing Update
063-Fusion 360 - Chamfer Toolpath Options
064-Fusion 360 Parametric Vise
065-Fusion 360 Modeling a Valve Handle
066-Fusion 360 CAM 3D Chamfers
067-Fusion 360 - Secrets of the Dimension Command
068-Fusion 360 Modeling Practice
069-Fusion 360 - Contour Selection Methods
070-Fusion360 Tool Library Preview
071-Home Garage Shop Intro
072-Jet Ski Lift Brackets
073-Fusion 360 - Toolpath Mirroring
074-Fusion 360 - In Process Stock Display
075-Garage Lighting Upgrade to LED Lights
076-Channel News and Website Update
077-Fusion 360 How to Flip a Part for Op2
078-Jetski Lift Replacement Brackets Fabrication and Completion
079-Fusion 360 Lathe Tutorial
080-Fusion 360 Hole Creation Methods
081-Fusion 360- Carryover Stock From Previous Setups
082-Fusion 360 NC Programs for Multiple Setups
083-Training Classes and Syil X7 Update
084-Using Fusion 360 with External Slicers for 3D Printing
085-Syil X7 - Speed Vise Handle First Chips!
086-Mechanical Advantage Update and News
087-Fusion 360 Press Pull Command
088-Fusion 360 CAM - Trace and Engrave
089-Saturday Garage Update
090-Fusion 360 Screwdriver Tutorial
091-Fusion 360 CAM Soft Jaw Tutorial
092-Machining a bottle opener on the Syil X7!
093-Fusion 360 CAM Understanding Blend
094-Machining a Blend toolpath on the Syil X7
095-Fusion 360 CAM Soft Jaw Tutorial Using Combine Command
096-Fusion 360 CAM - Adaptive Clearing Both Ways
097-Fusion 360 Adaptive Clearing Machining Time Results Comparison
098-Fusion 360 3D Flat
099-How To Run an Unproven Program and Not Crash with a Siemens 808D Control
100-Fusion 360 Post Processing Demystified
101-Mechanical Advantage Updates and Training Schedule
102-Understanding Sketch Constraints and Dimensions
103-Modeling and Toolpathing a Steel T-Slot Nut
104-Syil X7 Machining 1018 Steel
105-Part 1 - Creating Joint Origins with Fusion 360
106-Part 2 - Toolpathing a Go No Go Gauge with Fusion 360
107-Part 3 - Machining a Go No Go Gauge with the Syil X7
108-Fusion 360 - Optimizing Large Patterns to design a Fixture Plate
109-Fusion 360 - Designing a bracket to hold bar stock
110-Fusion 360 - What is the difference between Joints and As-Built Joints
111-Fusion 360 - Organize your files using Derive
112-Fusion 360 Parametric Self Centering Vise
113-Fusion 360 New CAM Geometry Selections
114-Fusion 360 - An alternate take on modeling a tutorial file
115-Fusion 360 - WCS Location Options
116-Fusion 360 - Geneva Wheel Modeling Tutorial
117-Programming Xometry Mill Test Part using Fusion 360 - PT 1
118-Programming Xometry Mill Test Part using Fusion 360 - PT 2
119-Programming Xometry Mill Test Part using Fusion 360 - PT 3
120-Programming Xometry Mill Test Part using Fusion 360 - PT 4
121-Model Engine Project - Cylinder
122-Model Engine Project - Cylinder CAM
123-Model Engine Project - Cylinder Machining
124-Model Engine Project - Cylinder Head
125-Model Engine Project - Cylinder Head CAM
126-Model Engine Project - Cylinder Head Machining
127-Model Engine Project - Engine Case LH
That was a lot of work you've done. Should be of use to many of us here.
Thanks
Ted
