- May 16, 2016
- 1,700
Maybe you're misunderstanding my question. I was talking about the bearing in use heating up and expanding not heating it in oil to install it.
I am wondering why in both cases you wouldn't have a tight fit on the shaft so as the bearing heated up from use it would expand and tighten up inside the housing. Seems no different to me whichever race is moving or stationary.
Just wondering the theory behind it. Thank you.
The theory is based on the idea that with a rotating shaft then the inner race becomes part of the shaft. In the case of a wheel then the outer race is part of the wheel. It's common engineering practice.
