- Sep 29, 2017
- 2,251
Hallo guys.
I am almost done with building my 50mm×2000mm belt grinder and I have the motor running the right way at present,but would like the option reversing the direction with a switch if needed. I am not an electric buff so please bear with me.
It is a single phase double capacitor motor 220V. Can someone guide me with a simple drawing on how to wire the motor to the power supply through a switch wich I can use to change direction between cw and ccw.
It is currently wired like the drawing on the right.
Thank you in advance.
Michael.
Michael.
