- Oct 11, 2016
- 3,879
@great white Thre are so many techniques that you might use, but showing a quick sketch (even in paint) would really help to focus our efforts. Some of the techniques would be totally wrong for some shapes, etc.
Is the square bit bigger than the round bit or the other way round ?So you put the square end in your lathe 4 jaw chuck, make the end that sticks out round. Then move to the mill, hold the round end in the mill vise with V blocks or a collet block, or a spin indexer, or whatever you can figure out, mill a side of the square, and rotate as needed for the other sides.
I saw one of those at a yard sale for $2, I thought it was broken.So far, following everybody's helpful input, the image in my head of what you are making is something like one of these parts:
That’s really funnySo far, following everybody's helpful input, the image in my head of what you are making is something like one of these parts:
First semester project. Separates the engineering students from those with actual potential.So far, following everybody's helpful input, the image in my head of what you are making is something like one of these parts:
it's a plinth to mount a ball cuter, tolerance isn't overly important on the outside dimensions other than parallel top and bottom surfaces, the center height (thickness) and the bore where it will mount to my Atlas cross slide. The radius on the forward edge is the radius of the ball cutter mount.What is the dimension and tolerance of the radius?
