How to cut internal Acme threads in a finished piece?
Did you ever consider epoxy or other plastic. I once wanted to adapt the male acme thread on the end of my aluminum boathook to allow a landing net to screw on. I cut the handle off the net leaving about a 2" stub of aluminum tubing. I plugged the bottom end of it, and filled it mostly full of epoxy resin and inserted the well waxed end of the booathook thread into it and set it up in a vertical position to cure. It screwed off fine and served me well for many years until I tried to land a good sized barracude when the boat was travelling too fast.
Michael
An interesting idea, Michael, but not applicable in this instance. Doing as you suggest would require boring out the existing 5/8" (approximately) diameter sockets I'm working with to accommodate the 3/4" Acme thread. These devices still need to mount on standard 5/8" photo baby pins. If the sockets were bored and epoxy filled to conform to the Acme thread, when attached to standard baby pins, the strength and integrity of the mount would rely totally on the strength of the internal formed epoxy Acme mold. Considering the potentially high value payload, I think only a tapped all metal socket will do. Thank you for the suggestion, though. It goes into the memory bank for future use.
Why don't you find a suitable roller cut off the end and make an adapter ....cheeessh and I'm unemployed :>)
http://compare.ebay.com/like/120841915337
Been there, done that:
The point of this exercise is to eliminate the need for an intermediary adapter (which may not be available when needed). By internally threading the baby receptor, the roller kludge, though effective, would not be needed.
Don't know then. I myself would learn cut the threads on my lathe. That would be the cheapest way for me to do it .....Why wouldn't you make the adapter a little smaller (shorter) and leave it attached to the part?
As I mentioned earlier in this thread, there already is a commercially available, shorter adapter:
http://www.kaceyenterprises.com/?page_id=447
Again, the mission here is to try to make standard photo baby pin receptors dual purpose, 5/8" and 3/4-5 Acme, without the need for an additional adapter. I think trying to run a tap into the socket is what I'll try.
I'm just tired ,I did see that post but that point didn't really sink in. You most likely will still have to bore out the hole for the tap? not sure how you would set that up do you have a lathe?
Just to give my 2 cents. I have cut many internal acme threads in my day. My thoughts are this. If the piece can be chucked in a four jaw or held in a fixture on a faceplate, I would cut a relief in the bottom of the bore the depth of the thread OD, make the most rigid internal threading tool possible, mount the bar backwards and cut the thread in reverse so the bar is cutting on the way out of the bore. This way you can put the tool in the bottom of the bore, set it to your depth , engage the half nut and cut on the way out without worrying about running into the bottom of the bore. Also if you set your compound at 13 degrees and use it to increment your depth you cut down on cutting forces considerably.
Unfortunately, no, I do not have a lathe which is why I asked if it might be possible to drive a tap of the required size manually. At this point, if I can find a reasonably priced tap, I'll give it a shot.
This is sage advice, I'm sure. However, you have to remember I am not a machinist and have neither the skills nor the equipment necessary to do as you suggest. Muscling a tap into an appropriately sized hole is really the best I can manage at the moment. If this proof of concept works out, it might be feasible to have a new baby pin receptor mold made that incorporates the Acme threads. If not, the part manufacturer may be able to sub out the thread machining step. We'll see. For now, I just need to cut the Acme threads in no more than four different pieces. Even one would get things rolling.
