O
ome
Forum Guest
Register Today
How to correctly use a .0005 res test dial indicator?
Trying to bring buck adjust tru to .0005 , Hi reveryone,
could anyone tell me what is the value of each line on the dial face of a B & S test dial indicator 599-7031-3 with a measuring range of .030" and 0-15-0 marking on dial face 1.5" dial face
I am showing on the dial when i turn the chuck with a test bar of 12-13 lines away from zero
on a .001 res test indicator it showed 1 thousandth off zero
also need to know absolute most rigid way of putting in lathe tool holder?
thanks for all your help
jon
jon
