- Jan 25, 2015
- 2,558
That probably sound confusing so let me expand on that.
I've got a motorcycle master cylinder. It's a typical Chinese bit of execution. Which basically means it's all there, but needs some cleaning up and adjusting.
The bore has a piston with seals on it and it runs back and forth to build pressure in the braking system.
In that bore is a drilled hole to allow fluid from the reservoir to enter the bore.
The problem is the hole was simply drilled and left at that. There is a burr (which is obviously bad for the seals and piston) and i would like to put a light chamfer on the hole edge to make life a little better for the seals.
Now the bore is only 19mm ID, so no real room to get anything in there. The drilled hole is even smaller, perhaps 1/8" of so.
I've seen rather expensive (what I would call) internal chamfering tools, but i can't justify a high dollar tool for a one time use and having it cost a couple times more than the master cylinder itself.
Can anyone think of a way I could do this without resorting to some expensive piece of tooling?
