- Jan 20, 2018
- 5,624
This would be the ultimate repair if the service is available. It does require removing the spindle.I would likely have it ground to cleanup and hard chromed and finish ground.
And, In Ca. it would not be easy to find the service, probably not so in Tx.This would be the ultimate repair if the service is available. It does require removing the spindle.
I'm guessing that's cost prohibitive for this $1,400 lathe. Any idea what it'd cost to do that? The sealing surface is ~71mm diameter or ~2-3/4" (I'm saying about because I haven't done a precise measurement yet).I would likely have it ground to cleanup and hard chromed and finish ground.
