- Apr 14, 2014
- 3,185
I seldom have more than one machine running at a time. If I’m welding, the lathes or mill isn’t running. i don’t have a big compressor anymore. Not really running a lot of air tools. I use air to supply the air gun more than anything else. So a little Makita compressor has been more than sufficient for me. I have a 100 amp sub panel in my shop. I have more than what I need in my opinion. My Miller 211 is more than happy. Now, if I had a 5000 sf shop...yeah, I’d have a 200 amp serviced. But I’d also have climate control in at least 1500 sf of it too.
FWIW... I just found some real narrow air supply line which is designed for air cylinders. I’m probably going to run some copper pipe on the ceiling and branch down with the poly lines to supply my air guns at each machine. I’m tired of tripping over the damned air hose.
You might want to try the Rapid Air system for your shop. It's relatively inexpensive and a starter kit comes with enough tube and fittings for 2 outlets. I bought 2 starter kits for my shop from our local farm store when they were on sale for $69.00 each. It took about a day to install all the outlets and plumb them to the compressor.
Here's a link to the system I purchased. They do go on sale from time to time.
RapidAir 1/2in. 100ft. Master Compressed Air Piping Kit, Model# 90500 | Northern Tool
The RapidAir 1/2in. 100ft. Master Kit is a compressed air piping system designed for automotive and woodworking shops, trailers or home garages. Us...
www.northerntool.com
