- Nov 23, 2014
- 2,607
Depends on where you want to spend your time. You can pick up a very nice BP in my area (Michigan) for $3000. No work required to get it up and running. I looked at a project years ago for $1000. Head made a ton of noise, table had been drilled/milled multiple times, surface rust all over, broken crank handles, lots of play in the table (gib adjustment?), etc. I had to budget to buy something that didn't need to be worked on and was making parts minutes after it was powered up. You could save some money on a fixer upper, but around here the price difference wasn't worth it in my case.
Might be best to find a nicer machine and not have to rebuild it. I always ask the seller why they're parting with the item. Not that they'll be truthful, but maybe they're tired of fiddling with the problems and bought something that works. Here are some Texas-area Bridgeports and clones on CL.
Bruce
$1500 - Acer 10 x 50
$4300 Sharp 10 x 50 CNC machine with controller issues
$1750 Bridgeport that needs work
$6900 Looks to be recently rebuilt BP
$5900 Sharp 9 x 48
$4500 BP 9 x 42
$4000 BP - step pulley model
$7900 RAM CNC mill
Bruce
Milling machine
For Sale. $1,500. Acer milling machine 10”x50”. Better shape than what she looks. Variable speed head, pretty tight XY and Z. Has Mititoyo scales on X and Y but no DRO. One shot lube, vise, chuck and
lubbock.craigslist.org
Sharp TMV Vertical Milling Machine 10x50 w Kurt D688 Vise T134513
220V/440 3 Ph Table 10x50 Spindle Motor 3 HP Table Travel x Axis 35 inches Table Travel Y Axis 16.3 inches Table Travel Z axis 5 inches Report: Control turns on, loads program but is reporting a...
elpaso.craigslist.org
BRIDGEPORT MILLING MACHINE
Nice Bridgeport milling machine. Recently head gear started slipping so it will require some work to make it fully functional. X,Y and Z axis tables move freely and no play between them. Wired 220,...
houston.craigslist.org
@~Bridgeport Vertical Milling Machine 42~@
!!!!!Hey S/N 6283 DRO on table Will entertain best offer Inspection is by appointment only, most weekdays and Saturday mornings. Feel free to contact me, Steve, with any questions by email or cell If
$5900 Sharp 9 x 48
SHARP VERTICAL MILLING MACHINE 3 HP 48 X 9" TABLE CHROME WAYS
SHARP VERTICAL MILLING MACHINE 3 HP 48 X 9" TABLE CHROME WAYS 48" TABLE DRO POWER FEED NEAR NEW Machine CALL FOR DETAILS https://machineinventory.shop/shop?olsPage=products
sanantonio.craigslist.org
$4500 BP 9 x 42
Bridgeport Milling Machine Model 1-VS - Power Feed
Bridgeport Milling Machine Model 1-VS Specifications: Table Size 9" x 42" Table Travel Longitudinal 30" Table Travel Cross 12” Table Travel Vertical (Knee) 16” Head Vertical Travel (Quill) 5” Quill...
dallas.craigslist.org
Good Bridgeport mill will little use. 3 phase, cane from college, working when removed from service and use used for training only. Located in Nederland and forklift in site for loading. Asking $4000
$7900 RAM CNC mill
➣➣NEAR NEW Cnc Milling Machine -Knee MILL 10 x 50 Table 4VH 3 Axis
WE HAVE ANOTHER ONE LIKE THIS BUT ITS THE NEXT SIZE UP YOU CAN DO THIS MANUAL OR CNC MODE SPECIFICATIONS SPINDLE NOSE R-8 SPINDLE SPEEDS 70 TO 4,200 RPM SPINDLE DRIVE MOTOR 3HP TABLE SIZE 10 X 50"...
