- Dec 18, 2019
- 6,464
Here's the measurements, I took of the 0.2490 and 0.2510 reamers, all 3 cutter positions (6 cutting edges).
Marking 0 deg 60 deg 120 deg
0.2490 0.24990 0.24990 0.25000 "under"
0.2510 0.25125 0.25105 0.25105 "over"
My conclusion is this undersized cutter is too large. The oversized cutter is satisfactory. These are measured back to back. Micrometer zeroed at beginning of measurement. Micrometer zero checked and was zero at end of measurement. Zero measurement = 0.00000". Mitutoyo QuantuMike. Anvils were cleaned using sheet of paper between the jaws, prior to measurement. Used a micrometer stand.
6 out of the seven under cutters in the box measure 0.001" larger than stated. The 7th one is on size or within tolerance.
For reference, I have a 1/4" reamer from Alvord Polk Tool (APT). Size on box: 0.2500". After cleaning any residual oil on it, this is what I measured.
0.2500 0.25015 0.25010 0.25005
Same micrometer, room, etc. This tool cuts seemingly to size on my mill, although honestly, I haven't measured it. I do know I have had zero problems with the USA reamers. Everything fit as expected. I found a couple of the APT reamers on fleabay, so I didn't get reamed.
I know what the message is, buy good quality tools... It's really easy to get tempted by these sets.
Seems that this set is going back... Not going to put up with this sort of creative cheating. The set is useless for my purposes. Now at my fourth attempt at getting a real 0.2490 (or 0.2485) reamer...
