You'll get good at it.Definitely watching this!
I tried sharpening a 1/2" bit that was beyond dull. Used my belt grinder and I was very surprised at how well it cut considering I had never tried sharpening before.
Take a known dull bit, put a little magic marker or machinist blue on the cutting end, try to drill with it, then look at it with a magnifier.
You'll see exactly where and what to grind, pretty soon it will come natural to you.
Tim
I use this version (from Lee Valley Tools) with my 1 inch belt sander:I have the craftsman version of the swing thingy (Like that name for it). Mostly I get good results yet sometimes not so good. Using the side of a grinding wheel gives me pause at times. I have also notice that I get a groove in the side of the wheel and have to dress the side. Maybe my wheel is too soft. I have no idea what make or grit it is.
I have seen a swing thingy used on a belt sander. Plan to try that out on my belt sander. The 1" belt may be too narrow.
I have wondered if there are wheels that don't cost an arm and two legs that don't risk exploding. I'd like to add a disk to my belt sander for sharpening drill bits. Might have to make a combo disk/pulley. There is enough length on the motor shaft to add a disk. Oh well. Another project for another day.
That’s the contraption I have. So you use on a belt sander? That sounds more logical as it’s flat, but what do I know about this topic?I use this version (from Lee Valley Tools) with my 1 inch belt sander:
Sharpening by hand has never worked for me. Maybe I'm overthinking it, but maintaining a contact angle while rotating and swooping the drill seems...challenging. For me, the jig is very quick and consistent. It automatically gives the clearance behind the cutting lip. Even horribly mangled bits can be resurrected in just a few minutes. All for $25 (Canadian).
The jig has it's limits, though. 1/8" through 3/4" sizes. Extra long bits won't fit. You may need to put a collar on S&D bits to get them to register properly.
Craig
PS Many, many years ago, I did some project work in a place that made grinding wheels. One of the key takeaways was that you don't want to be anywhere near an exploding wheel. Ever. Using the side of the wheel is not recommended. That's why I have this jig set up on the belt grinder. YMMV.
PPS Just realized the picture above shows the jig improperly assembled. The part that supports the tang of the drill is on backwards.
