- Sep 22, 2010
- 7,223
This question was asked by a SB owner on another forum, not answered directly.
The oil cup on the right side of a Heavy 10 headstock is screwed into the adaptor bushing and then pressed into the headstock as an assembly. If the cup will not rotate around, you must pull the cup bushing and then press it back in.
I damaged mine, as others have, trying to unscrew it (luckily I bought other gits oilers).
How would you pull the bushing using, I presume, a slap hammer and how would you press it back in WITHOUT CAUSING DAMAGE.
(Photos would be awesome if you have any!)
Thanks,
Nelson
Thanks,
Nelson
