- Sep 2, 2013
- 5,138
I'm guessing it was knocked over or dropped while being moved, and was bent. Close inspection by mounting on a straight shaft (or just back on the pump if your sure the crank is true) with a pointer on the outside diameter would show where it's out. If it bent one way, I bet it would bend back with the proper setup. The approach Mr Whoopee pointed out would also be an option. Mike
