- Jun 8, 2016
- 603
Do you plan to re-add a power feed? If, so, it will include a needle bearing. If not, you can probably get the bearing number from the bracket at the other end of the table. I installed a power feed on my Chinese "Bridgeport clone" PM mill. The bering in mine was a 6204 (20mm ID).
Power feed is on the list of things I would like to have, however I'm not planning on doing it right off the bat. That plan could change though if adding the feed is a less expensive option in some way to fix the missing end, but I don't think it will be.
Really need to get it apart and cleaned and see where I really am.
