- Feb 8, 2014
- 494
In my other life a a corporate maintenance engineer we had a constant water problem in our compressor operation. Each plant had no less than 3500 (yes 3500) horsepower of compressors on line at all times 24-7-365. I found the best auto drain was a 3/8 " motorized ball valve with a built in timer, they could be set for various schedule of operation & had a test switch for manual operation. On schedule the valve would slowly rotate open & close. At 3/8 inch dia it never plugged up. For smaller air receiver we used a plug with a small orifice to reduce the pressure drop but most of the receivers were 6 ft dia X 15 to 20 ft long. Believe me I tested MANY no fail drains that failed.
fixit
fixit
