- Mar 22, 2013
- 215
The flywheel looks great! As are all the other pieces. When I built mine the castings were still available so not wanting to carve the large flywheel from a chunk of iron/steel I bought the casting. I also bought the intake and exhaust manifold castings. When I made all the modifications and revised the drawings I showed how to fabricated the manifolds so they looked close to the original shapes. This requires a bit of silver soldering but shouldn't pose any problems. Your mounting for the flywheel should work fine. I learned a long time ago that set screws/grub screws won't hold a flywheel in place so that is why I went with the keyway.
gbritnell
gbritnell
