- Oct 13, 2014
- 6,752
Important trick: A blade that has the teeth "backwards" can be reversed by turning the blade "inside out". Like, flip the surface over and work it all the way around. Voila', the teeth will be facing the other way. I have to do this about one time in five as the process of taking the wire-wraps off and getting the blade out of the shrink-packaging has it come out "backwards".
Note that I only came across this stuff while researching my blade issues, but here are the sources:
http://www.starrett.com/docs/saw-resources/recommendations.pdf?sfvrsn=2 (This is from the blade manufacturer)
http://www.bandsawblade.com/breakin.htm (Similar here)
https://www.sawblade.com/breaking-in-band-saw-blades.cfm (and again)
http://www.wikussawtech.com/index.php/en/einfahren (another blade manufacturer)
So like I said, this was all news to me, so I'm not preaching this stuff as gospel, just that I discovered yet another thing that I, as an untrained amateur, hadn't heard of until now that could be affecting blade life.
Wow, I guess there's some truth to it then. One of those things that doesn't seem to make sense but...
