- Nov 28, 2016
- 2,375
I worked on the taper attachment clamp this morning... I've finished boring the piece that goes on the taper attachment end of the clamp. While test fitting it, I noticed that the threaded rod that it slides on is bent.
This is basically a piece of 3/4" all-thread that mounts in the end of the lower slide... it is also pretty badly rust pitted, so I decided to make a new one... I had a 3 foot long piece of 3/4" all-thread already, so I just cut an 11" piece and cleaned the ends up.
I found a piece of 5/16" steel plate to use for the center piece of the clamp. I eyeballed the angle from the bed end of the clamp to the threaded rod at about 18 degrees, so I went ahead and set the piece of plate up on the mill at 18 degrees and bored a hole in it to go around the vertical piece on the bed end of the clamp... (maybe all of this will make sense as I get it all fitted together)...
Anyway, this is what I have right now...
I have a good bit of milling to do on the plate yet...I'll have to carefully fit both ends, mill angles on both sides, then weld it all together. I also still have to make the vertical rib that goes down the center.
Stay tuned... I'll get there eventually...
-Bear
-Bear
