The problem with that weak abrasive saw is that the blade is not cutting hard enough and it gets glazed. Then, it doesn't cut. It just wastes power and glazes more. If you want to cut larger bar stock, either use a band saw or a real abrasive saw. The real abrasive saws are not under-powered. They have a 3 phase induction motor and multiple belts
