    Dismiss Notice
Help With Power Supply
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by speedre9, Jul 11, 2017.
  1. speedre9
    speedre9 United States Active User Active Member
    4
    18
    City:
    Pelham
    State:
    New Hampshire
    -Return to Top-
    I got this power supply originaly for LED's and it has the following
    360W, Input 100-240V 50/60Hz
    Output; 5V, 12V, 24V, 36V, 48V. This is where I lose it. There are nine screw lugs,
    three are for L,N,G., I get that, The remaining lugs are +V,+V,+V, com, com, com.
    So how does the power suplly deliver those different output values. Can I connect
    to any of the three or is there a difference? I'd like to use for my 3D Printer.
  2. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,416
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    I( would guess that the three output are isolated so that you can connect them in series to get the various voltages. A 5 volt output would be one. Another would be the 12 volt and the third would be the 36 volt. If you connect the 12 and 36 volt in series - to +, you would get 48 volts. If you connected them - to - or + to +, you would get 24 volts. It isw kind of a kludgey way to get there but it would work.
    Use a voltmeter to identify the three outputs and check the different combinations.
    fixit and brino like this.
  3. tq60
    tq60 United States Active Member Active Member
    177
    43
    City:
    madera
    State:
    California
    -Return to Top-
    Best to test it.
    Connect L1 and L2 to line power then check the voltage outputs.
    Check every combination as some may okay not be isolated
  4. strantor
    strantor United States Active User Active Member
    206
    63
    City:
    Katy
    State:
    Texas
    -Return to Top-
    can you give the model number and/or pictures? Without that all you get are guesses.
    My guess is that the 3 sets of +V and -V are common (tied together) and the power supply output voltage is selectable.
    Several DC power supplies I have seen have duplicate terminals.
    For example this guy:
    [​IMG]
    The + and the other + are tied together, same for the minuses. This is for when you have several loads that all need to connect to the same supply; more terminals to land the wires.
    RJSakowski likes this.
  5. RJSakowski
    2,416
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    This makes sense. I have seen power supplies like that. I have also seen packaging that lists a variety of available voltages. Usually voltage pertaining to the power supply in the packaging is checked. The voltmeter will tell.
  6. chips&more
    chips&more United States Active User Active Member
    1,181
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    Do you have a volt meter?
  7. strantor
    206
    63
    City:
    Katy
    State:
    Texas
    -Return to Top-
    Yeah maybe a sticker with several voltage check boxes is on the P/S and one of them is/should be checked
Share This Page
