- Apr 29, 2023
- 11
Hi all,
The 1960s Rockwell 21-100 mill I recently acquired has - I believe - a single phase motor but is missing the name plate. It came wired as single phase and worked when tested.
It has a Furnas reversing switch (momentary push-button switches) and Furnas reversing contactor.
I went through the electrical box and replaced a number of wires that were corroded, cleaned up connections, and improved the mounting of the transformer. After that, the motor will not start reliably. Testing with a multimeter told me the start capacitor was bad, so I got a new one. that did not help it.
If I manually help the motor start turning, it will usually pick up and run normally (clockwise, anyway - CCW seems to be a problem). That is a dodgy proposition, though, trying to nudge the pulley along inside the housing .
So, question #1: the motor won't start itself. Any suggestions?
Question #2: the contactor latches solidly and quietly about 20% of the time - the other times is buzzes either a little or a lot. I've checked the switch circuit voltage (24VAC) and it seems to be fine, not dropping significantly when activated.. Is that a symptom of the contactor coils going bad?
Attached are some photos. Appreciate any help you may have to offer.
Thanks,
Ray
Thanks,
Ray
