- Apr 30, 2015
- 11,338
These kinds of caps are not polarized. Peel back the plastic and see if there is really a hole there. I would expect to see some capacitor "juice" coming out if there was a rupture. Also, caps like these usually have a pressure plug on top which blows first. Besides, momentarily shorting the ac power and tripping the breaker usually doesn't cause capacitor damage like that.
Since you reported different behavior between forward and reverse there must still be an issue with the switch or wiring and/or jumpers.
Do you know for sure the switch internal contact arrangement is the same as the old one? Did the switch come with any diagrams? Do you have a multimeter available? We may have to "ring out" the switch to verify the contacts. I can help you there.
One important point on this model is that there are two blue wires coming down from the motor to the switch- if those are swapped it won't work properly
-Mark
-Mark
