- Feb 1, 2015
- 9,622
It is a confusing drawing! tbell is right; it is a clearance hole for M6.shown below. means depth. I have never used it in my drafting classes. I had to search Google to find it. Not sure what the designer is having you do. You are drilling and taping then re-drilling the same hole. A three place decimal could be a reamed on size hole as well. There should have been a front view of the drawing showing the holes for clarity.
The Best with your project.
That said, there is no drill spec for the tapped holes. The convention that I normally would use is as shown below. Drill .0983 hole to .300 depth, tap M3 x .5 to .2400 depth. If I wanted to provide for clearance hole above, say for a shoulder bolt, it would be on a third line expressed as a counterbore ( l_l , my attempt at the c/bore symbol) giving diameter [ c/bore symbol] c/bore depth. A final note: the drill depth is to the shoulder of the drill, not the point.
