- Dec 20, 2012
- 9,422
Have you tried removing the scroll & check if the jaws move freely in the slots? I would start from there.
Listen to Will. Take a hardwood dowel that fits in the jaw slot and tap in each of the slots until the scroll breaks loose. The jaws should slide freely after that. If not, then you have some chips/debris in there. Clean everything, lube it properly and reassemble. The chuck should work fine.
